Replace knock sensor and spark plugs project with pics (as requested) HOW TO
#61
#62
You have to use a ratcheting box wrench with a joint. https://www.ebay.com/i/401948875874?chn=ps&var=671799101699&norover=1&mke vt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=671799101699_401948875874&targeti d=915282956376&device=c&mktype=pla&googleloc=90324 49&campaignid=10460112669&mkgroupid=101996180325&r lsatarget=aud-412677883135la-915282956376&abcId=2145998&merchantid=6296724&gcli d=CjwKCAjwsO_4BRBBEiwAyagRTXj5V1rkCMJIXzIKQdnqG3WV zcaoSFDU834VQucxkNSH_jpfDoEYnBoC5c8QAvD_BwE
#64
Blaydes99 so it has been 9 years since this was done? Do you still have the X-type and is it still running well? I am getting ready to do this job. I was just going to replace coils and plugs but, I am going to replace that knock sensor since the engine will be open. do you only have to drain the coolant when replacing the knock sensor? I hadn't read anywhere about the coolant on replacing the plugs. thanks again for the great step by step info.
#65
#66
Seems like it is compatible with the X-type from what I can tell. Just watch out depending on if you have a 2.5 or 3.0 engine to ensure it will work.
xjrjag
10-27-2021 11:48 PM
X_Type_South_Africa
12-09-2015 05:37 PM
