replace non memory drivers seat with memory seat.
changing the drivers seat to memory is straightforward, its easier to change the whole seat rather than the bits under the seat as each motor would have to be changed.
The non memory seat will have a single multi plug the memory seat with have the same plug but also a smaller grey plug next to it. you need to add a feed from the switched ignition feed on the multi plug to the grey plug and also the can bus ( twisted yellow green) from the climate control unit to the grey plug . the seat will then work and store positions, the memory mirrors are a bit more complicated.
I can send you some photos of the wireing if you want to proceed.
