Replaced Parking Sensors
Hi all... after loosing my patience trying to sort out the factory fitted parking sensor set up, I opted to remove it and install an after market set. The installation went well but I've hit a bit of a snag, when I engage reverse gear the reversing sensors come on but they give off a warning code.
The kit comes with the optional canbus wire but I'm a bit stumped as to whether the car has the canbus system (2004 X Type saloon) or where the canbus wire would be attached?
Anyone any ideas?
Anyone any ideas?
Received 3,887 Likes
Neiltheman75 (02-16-2016)
Thanks for the feedback. I've two plugs in the spare tyre well, both have a white wire but neither is at the pin 12 position. I've tried connecting the canbus wire in both but I'm still getting the same fault alarm coming from the sensors (a cisbo parking sensor kit).
Not sure if it's a dodgy sensor or if I'm not finding the correct wire
Miss Daisy (my daughter named her) was manufactured in May of 2004. I'm wondering if you have a download link, or a copy of the electrical manual & schematics as they pertain to my car.
Thanks,
-M
Check out: https://www.jaguarforums.com/forum/x...nks-faq-34883/ . There you will find a few links to where diagrams are listed. If you want the whole JTIS handbook, look up in the sticky section and there is a link to download it and how to install it into the newer operating systems.
hobbs (02-18-2016)
vsol
02-17-2016 08:49 AM
car5car
02-10-2016 09:20 AM
car5car
02-07-2016 12:51 PM
