Replacing Base Model Struts/Shocks with Sport Suspension Struts/Shocks??
Hey guys-- is it possible when replacing my High Series 2004 X Type (w/3.0L) front struts to order replacement struts (w/sport suspension) instead of the base model (w/o Sport Suspension)??? Is the sport suspension strut just a bit stiffer ride, or are there other physical differences in the actual part?
The reason I ask is because the struts and shocks for X Type vehicles with sport suspension are cheaper than the base model struts and shocks... go figure?!!?
Thanks in advance for your assistance!
ehaglund, should work, but also keep in mind that the sport model X-Types sit 1.4" lower than non-sport versions. So, upward travel is not much of an issue, but you may find that shock damage may occur if say you hit a pothole and the wheel is allowed to go to full travel down. Something to think about. It may be one of those things that you would need to give Bilstein a call and see if the overall dimensions of the shock are the same (ie, full extension length, full compression length) a the only difference is the valving.
philwarner
12-06-2021 07:13 AM
Fraser Mitchell
10-01-2015 04:06 AM
