Replacing existing Amplifier with Aftermarket
Hello all-
I have been racking my head trying to figure out how to get the final piece in my instal. I think when I have asked this question before maybe It was too convoluted.r
So let me reduce it to this:
What's a good AM Amplifier to replace the stock? Please keep in mind the only thing that is "D2B" is the input to the factory amp. NOT THE OUTPUTS!!
so What I want to do is connect all the factory outputs to the speakers (circled in pink) --as they are--to the new AM amp
. I want to use the existing stock battery power cables (there are two) circled in blue to power the new AM amp.
And the ground (there are two) stock cables circled in orange to ground the new AM AMP
I see the rear speakers and twitters use one Chanel
i know now it's possible to use all the stock wiring. I have a couple of friends with Porsche 's who have done this when replacing their D2B- AMPS. I also know someone with a Mercedeces who did this when replacing his MOST Bose AMP.
I just need need to know what is a good replacement AMP and how to connect it to the stock outputs. Something that won't blow all the existing speakers, keep the current sound quality, no more no less.
as always help is greatly appreciated.
Just for closure purposes, Crutchfield helped me find the solution to my problem.....I wanted to connect the after amp using the all the stock amp connections, including the power source. No rewiring to speakers necessary, just using all the stock connections . Remember the stock amp has two battery powered cables and two grounds.
The soulton was two compact Alpine KTP445 U mini amps. It's 4x45..... 8 Channels total between the two as the stock amp. One will power the front tweets and speaker, one will power the rear parallel tweet/peaked and each sub. Will update on quality of sound once I am all done.
