Replacing the fuel pump
Hello all,
I am replacing my 2003 x-type's fuel pump. I am going to drop the gas tank, and have been following the excellent guide that Paulc732 posted https://www.jaguarforums.com/forum/x...al-how-143763/
I have gotten to the point of removing the exhaust, and I removed the 15mm bolt from the clamp near the diff.
The bolt itself is stuck on it, but the clamp has loosened. I am not sure exactly what to do from here. The guide says to heat up the pipe and then knock it loose.
If I do that, will it go back together?
