Replacing X-Type Headlamps
Is it as simple as popping in a new bulb? Or is there some aiming involved? The last time I aimed a headlight, it was back in the 80's and I didn't do a good job. Granted it was a 79 Ford Mustang. So I don't want to screw up my Jag. Even if it is a wagon.
[IMG]local://upfiles/5568/38C6051FBD244E5DA00A395CA4EBBF1E.jpg[/IMG]
Received 9,010 Likes
Guest
Posts: n/a
he said headlamp (bulb) not the housing
yes all you do it put the bulb in! takes a couple minutes. you have to pull the caps off the back of the lights, then theres a little metal tab you open up like a hinge, and then pull the bulb out.
http://autolumination.com/headlights.htmhas the best prices.
scroll down. x-typehigh beams and low beams are H1 55watt.
KarimPA
09-03-2015 07:32 PM
