Restore Engine Treatment
Received 3,887 Likes
Received 2,190 Likes
yeah thats funny cause I have gotten great results for engine restore for years. Have used it in cars with low compression and ALWAYS improved compression. And have recommended it many times here because of personal use as well as recommending to people with nikasil issues on their engines....Whats cheaper, engine rebuild costing thousands. or useing a $10 bottle of engine restore with each oil change per directions??????....Now if you dont have a compression or oil consumption issue then the use is really mute......
In general it's best not to use any product that's designed to CLOG in any system that's designed to FLOW. But I've never seen any issue with engine restore as that's not exactly what it's designed to do.
Years ago I worked in an engine rebuild shop and developed a hate for radiator stop leaks. Specifically the powdered ones. Almost every engine we got that had failed early had this crap clogged around the water jackets near the cylinder bores and it clogged the water passages everywhere it could. This of course reduced the flow of coolant in the engine and was a major cause of overheating. It's just better to fix your cooling system and avoid stop leak products if possible. I think this same thinking is applied to the engine restore type products but isn't relevant in all cases.
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
