Review mirror wires
Received 3,905 Likes
louvit, here is the info that you are after. You don't state what year car you have so the wiring diagram that I have is for a 2004.25 or newer vehicle.
Pin 1: Black with a red stripe
Pin 2: Black
Pin 3: Black with a pink stripe
Pin 4: Black with an orange stripe
Pin 5: Black with a green stripe
With this information, if you look at the first picture that you have in your thumbnails, , the left side of the picture is pin 1 (the wire with the insulation pulled back about 1/2" or so) and the right side would be pin 5 (black wire with the green stripe). You can then count across as the pins are in order.
Pin 2: Black
louvit (01-21-2016)
Pin 2: Black
Pin 2: Black
I have an 02 x type 2.5
louvit, I will need to get home to confirm the wiring (should be the same, but not 100% sure). I am currently "trapped" at work for 48 hours during this big snow storm hitting the mid-atlantic area (guess people want power to their house). So, I don't have access to the diagrams to confirm.
As for getting things "back to 100%", I would work on getting those pins out of the socket (should be little metal "slivers" holding it in place that a jeweler's screw driver will collapse and allow you to push the pin out the back of the plug, ie, the side the wires go in). From there, you can buy just about any other plug that would be similar to that plug and use the pins out of that. This is going to make your life a whole lot easier and you should be able to pick up a plug for just a few bucks. From there, you can solder the wires to the new pins and then slide them in to the old socket.
louvit (01-23-2016)
Thermo, your the man, used a dental tool, pushed in on the clip and they came right out........
thanks sent to you.
Now look at my other thread about my trip and fuel functions not working....lol
https://www.jaguarforums.com/forum/x...ulater-156234/
Lou
thanks sent to you.
Lou
louvit, if you go to NAPA (they seem to have the largest selection of electrical plugs), you can find a generic plug with that style of metal clip. Do not worry about the shape of the plastic connector as you are going to throw that away. Just make sure that the connector has atleast 5 of those clips in it. From there you should be golden.
Let me get home so I can look at my diagrams and I will see what I can do for you about the mileage calculator. I am stuck at work. I'm on hour 36 of work. Hoping I get to go home in 12 hours. BUt, this blizzard is making that all questionable.
louvit, no, you can do it that way. It is just easier to use new clips than it is to try and re-use the old ones. Also, if the plug has gotten warm, then the clips may have some corrosion on the connector which can lead to issues. Starting with new stuff just helps to minimize any chance of re-introducing a problem.
yea the clips are fine and the wires went in easy and I twisted them then crimped them into place, now I have to strip the ends of the short wires coming from the headliner in the car so I can splice them back on. That may be a pita because it's hard to work with short wires. No room for error...lol
I broke the last tail of the clip. I shoved the wire in and will solder it, it was the top tail of the clip so I think it'll work. Did you double check the wire locations in an 02
