RHS idicators stopped working 2008 x type estate
Hi Please can anyone help. I have a Jaguar x type estate 2008.
All 3 drivers RHS side indicators have stopped working.
I have checked:
All fuses
Bulbs
Fuse and bulb connections
Indicator stalk
Instrument arrow flashes and clicks fast as if a bulb is out
have checked all connections
there is a low voltage from stalk to gem for both left and right yet only the left has power coming out from the gem have tried another GEM with same results
have been told it could be a short yet ive checked all wires i can get to and have yet to find anything
any help would be much appreciated
thanks
I have checked:
All fuses
Bulbs
Indicator stalk
thanks
Did you have bulb die and replaced prior to this effect happening?
Have you got an incorrect or incorrectly fitted bulb shorting out the system?
Looks like front RHS indicators driven out of different GEM output from the rear RHS.
Different earths for each bulb cluster too.
You might need to isolate the two RHS outputs from your GEM and hang a test bulb off each output to check if you have normal operation before you go hunting through looms, sockets and bulbs.
CarLuva
01-11-2019 11:04 PM
03JagSType3.0
04-23-2017 10:47 AM
