right front C V axle replacement
Thank you ThomasX and bob for these replies. I'm just gonna inspect the inner seals as best as I can, lightly grease the snap-ring and coax the new axle back in there.
If that "mid shaft" is supposed to be part the tcase I sure wish a new one didn't come attached to my new axle- looking like one fine piece of kit! I have 15 years if experience as a shadetree mechanic and I'm feeling aome serious pain from this mistake- and as much as I try to always look at my role in any problem/situation, I kinda want to slap an old british engineer right now..
Fuh!
Fuh!
You bolt one end to the case and the round peg goes into the splined end of the shaft.
The shaft cannot be removed far enough to damage a seal but far enough if you need to remove the transfer case.
Illustration 18 on page 15 of the attached TSB shows how to use the tool.
bob
bob
bob
Hi Everyone,
I'm new here and will be going this morning to look at a 2003 X-Type 2.5 that will be gifted to me. I could have taken this Cat 2 years ago but I didn't need a car at the time. So in speaking with my friend last evening I found out it what he meant by center transfer case was not a center support bearing as he said it leaked? He had replaced the right CV joint and pull it out in one shot in one piece and replaced it the same way. Yes, IT LEAKS very badly now. The dealer or mechanic wanted an arm and a leg to repair it. I have a couple of question to this problem:
1) Is the fluid that's leaking Transmission fluid?
2) I read the entire post - may be a little too quickly but it's seems it requires a tearing down or apart in order to replace the seals?
3) Is there a post on fixing this problem? Thank you in advance for your help.
Blessings,
BKM
Blessings,
BKM
Ok, so I know this is an old thread, but I am a new wrencher to this cat. I have a couple of questions, first, has anyone put the through-shaft back in without the clip at all, and ran the car that way? I, reluctantly, pulled the shaft out slowly, turning along the way, as was described in another thread (I've read soooo many of them now). It came out surprisingly easy, then I seen why. There was no clip on it at all. It doesn't appear that it had any issues running without it. But I don't want to risk a catastrophe....
Second, I didn't destroy it, but I mauled the seal between the two shafts a little trying to remove it. Has anyone found a suitable replacement to use, an o ring or maybe some other plumbing seal, or ????
Thanks in advance for any help and input anyone has.
Bobby
Bobby
Hi,
thanks for the good information on this thread.
I wonder if the right CV axle is the same as the left one.
Because there are right ones that you can not split. Like in this link:
https://www.daparto.de/Teilenummernsuche/GSP/218240
This one :
Https://www.daparto.de/Teilenummernsuche/GSP/218027 is for the left side, if I use the spilt method can I use it for the right side?
This one :
#30
#31
#33
Hey new to the car and the forums. When I pulled my cv axle I found this forum much too late and had it all pulled out as one unit. Didn’t even realize it was supposed to be 2 separate parts until install. It came out with a light tap and no clip of any sort on the end which confused me to begin with but didn’t think anything of it since. Trying to put it all back in as one peice again I rotated it till splines lined up and with a light push my hand it clicked in about 10” so 3.5” roughly still sticking out. After that I noticed it wouldn’t come out again and it also wouldn’t go in any further,
stuck in a pickle here and can’t figure out why the heck it’s stuck
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
