Rims what size
newjag2002, the X-type has several OEM wheels that fit. 16, 17 and 18`inch. If you are wondering about wheels from other models fitting, S-type wheels will but the offset is slightly different, about 8mm and could be wider than what comes on the X at 8 inches rather than 7 and 7.5 inches.
as far as tyhe clutch and wiring, you can check with our on-site vendors like Nalley.
Failing that, exexpat and Thermo should be along to discuss all things wheel and electrical related. I hope.
