Rough idle at startup
RE: Rough idle at startup
Check underneath the plastic in your engine bay...remove the 4 screws pop it off (after removing the oil cap) and you should see a hose running front to back that may have a crack in it...this was my problem but it didn't trigger any lights for a couple of months.
Guest
Posts: n/a
does IMT stand for Intake Manifold Tuning?
FJT, what part exactly goes on the brake booset vacuum hose? just the check valve?
do you replace the hose with the check, or do you just put a new check valve?
what symptoms come from the booster vacuum line problems? just engine problems? or does it give brake problems too?
IMT is Induction Manifold Tuning. They are basically just a butterfly valve that allows air to flow at a different rate based on engine load. Full throttle, wide open valves. Personally I have disconnected them electrically and saw no difference in the way the car ran.
Sorry for the late reply Bo.
Do you guys know if this is BAD?: when i opened my Intake Air Control Valves, i saw some oil inside. Dodnt know if that is a good thing or not.
My car is also running rough on cold weather start and i can hear weasling noice when driving in the begining. Also a stiff brake pedal for the first minute after start.
Will check brake booset vacuum hose tomorow.
