Running problem
Running problem
Hi guys I am hoping someone might be able to help me with a problem with my car I have a 2008 2.2 x type and my problem is when at slow speeds it seems as if every minutes it feels like it is being pulled back a touch then stutters then clears for another minute or so and it gives a bit of smoke when you accelerate then clears and the car runs fine I am also only getting 26 miles to the gallon it shows warning lights and no fault code I have replaced the turbo actuator with a reconditioned unit cleaned the maf sensor replaced the cam sensor,map sensor fuel filter air filter and a new egr valve and have had no luck rectifying this fault and I am at a loss on what to do now I love this car but this is driving me mad any help would be appreciated thanks.
Received 2,692 Likes
Received 3,932 Likes
That symptom would normally be sticking egr valve or air being drawn in on the fuel line.
As the fuel injection pump has a built in lift pump, and the highest fuel line points is around the filter that also has o ring fittings, I would suspect that area.
Also if your new egr valve is non genuine one, don't rule out that this may be faulty.
Paul.
Paul.
shootingbrake
09-23-2015 10:54 AM
