rust already?!?!
Old 01-18-2008, 04:43 PM
jvegas's Avatar
Default rust already?!?!
I have a 2003 X-Type and it has about 60k miles. This car looks like it just rolled of the show room floor. I mean this car looks like it is brand new-perfect! However the other day I noticed rust inside the door jams on the front of the car. Kind of like in the bottom corner near thehinge.You can not see this rust from the outside at all when the doors are shut but once you open the doors you can see it. The car does not even have a scratch on it but this rust???? Has anyone heard of this as some sort of common problem with this car??
Old 01-18-2008, 05:03 PM
Cadillac's Avatar
Default RE: rust already?!?!
I didn't like this . Have it repaired soon otherwise some WD40 should be your call
Old 01-18-2008, 06:15 PM
Dennis's Avatar
ud
I have an 03 as well and it is as spotless as you described yours...Like Caddy said..this is not right..get it to the dealer, as I think (don't quote me) that there is a rust warranty, that islonger than the 4 year/50k..
Take some pictures for us...
Old 01-18-2008, 06:17 PM
jvegas's Avatar
here is the problem. The rust is on the body of the car. (will take pics soon and post) not the hinge or anything like that. It is only on one spot on the car but on both sides. Has anyone heard of this? I will but up pics tomorrow. any tips or anyone else that had this issue would be great help.
Old 01-18-2008, 06:28 PM
Doesnt matter where it is. There is a corrosion warranty on vehicle which is normally 8 years unlimited mileage. Refer to your owners manual for specifics. You should be able to take to dealer and get it fixed under warranty due to the corrosion warranty. When they look up your car at the dealer, DDW will show the date of expiration for corrosion warranty.
jasonzimbran's Avatar
the 2001 maxima that I have is SPOTLESS, no scratches or dents or any sort of exterior wear. No rust at all here but a 2003 with rust, damn man.
Old 01-18-2008, 06:47 PM
Received 9,011 Likes on 4,114 Posts
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
+1 on Dennis's and FJT 's comments Jvegas.............especially if the car is mint like you say.
The corrosion warranty should kick in, job done mate
Jim
Old 01-18-2008, 08:28 PM
Right the Service Portfolio book says:
Paint Surface Warranty Statement
"Should the paint surface of the vehicle body requrie attention due to a defect in material or application, any necessary reapirs will be undertaken by a jaguar Authorised Repairer, completely free of charge"
"Duration of the paint surface warranty - 3 years, unlimited mileage"
6 years, unlimited mileage corrosion (perforation) warranty statement
"Should any part of the bodywork of the vehicle be perforated by rust[/b] corrosion, the panel(s) affected by the perforation will be repaired or replaced by any Jaguar Authorised Repairer, completely free of charge, regardless of any change in vehicle ownership"
"Note: the term 'perforation' means a hole that penetrates through the bodywork, caused by corrosion from inside or underside, as a result of fauly manufacture or materials"
Jim
Old 01-18-2008, 08:43 PM
Dennis's Avatar
ud
My take on that comes down to prudent common sense on the dealer..Ifthey didn't fix the surface rust of his car now, because of the definition of rust perforation..they will indeed be fixing it later for just that, if it is left to go..like cancer...Besides, I can't imagine they wouldn't fix it anyways.
Old 01-18-2008, 09:13 PM
ancientsanskrit's Avatar
If there's rust in that area, definitely check on the underside of the door.
1.) Get it done through warranty
2.) If for whatever reason that doesn't work (which it should), do not use WD-40. It's too abrassive. I've done rust repair as the Contours love to develop rust on the underside of the doors.
What you want to do is sand down the rust, treat it with a product called rust coverter, re-sand, touch up and clearcoat. I do this every couple of years, and the rust is contained, it looks rather fine. Again, get it done through Jaguar as you should be covered.
Old 01-18-2008, 10:49 PM
jvegas's Avatar
WOW that would be great if it was covered! The only thing is the car is a 2003 so it is 5 years o;d and it has 60,000 miles on it. If I understand, rust is covered for life by Jaguar??? Is that correct?
Old 01-18-2008, 11:00 PM
jvegas's Avatar
That does not sound good.... my hopes...crushed.
I am going to go up to the dealer tomorrow and see what they say. I would be happy for now if they just fixed the A-frame. I will let you guys know what goes on. I seem to have a way to get things done when stuff goes wrong. I hope I can just "get it done" tomorrow. Thanks
Old 01-19-2008, 12:01 AM
aquill1's Avatar
Hopefully it works out fine...bo's dealers in Canada have been terrible for everything not just this one incident! I'm going to check about my hood rust spot as well Monday morning...Mines not terrible but like cancer it creeps up quick!
Old 01-19-2008, 01:19 AM
Chas944's Avatar
Being a new X-type owner rust was a concern for me especially living in the rust belt of the US. Has anyone had an experience with Ziebart for thier rust proofing applications? I would rather head the rust off before it becomes a "perforation" or cheese grater!
http://www.ziebartcarcare.com/rust_protection.htm
http://www.carsavers.com/rustprottips.htm
Old 01-19-2008, 04:28 AM
Cadillac's Avatar
It rusted badly [:-].I believe if they used aluminum you wouldn't get any rust .
Old 01-19-2008, 06:36 AM
aquill1's Avatar
I don't know chas, if there was already any chemical reaction already started the ziebart would only seal it in there. You could always take your plastic panels off and check everything out! You plan on keeping it forever or just a couple of years?
Old 01-19-2008, 11:16 AM
Dennis's Avatar
ud
Just a passing FYI and I'm sure I'm singing to the choir..But I was born and raised inMichigan and Wisconsin..and of course Ziebart was the first thing you did to a new car..But wasn't a for sure prevention against all the salt and slop you get in those winters..The number one thing you can do for prevention..Is to give your car a run through a carwash (brushless type)that has the undercarriage wash down...This will help a lot, not perfect, but better than just a topical hoses down...
I hope Jaguar will fix it for you..
.02
Quick Reply: rust already?!?!
