rust the size of a silver dollar on each side(under door) of XTYPE
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
I washed and waxed my x-type today and it seems that when i open the (front) doors there is a little bit of rust started to be visible I read another thread today on this site and im quite paranoid as to the extent of this issue,(the other thread said it is the a-frame? or piece and it makes the car very unsafe to drive) is there anyway I can fix this(without paying several k) as I have kept the x in prestige condition .
thank you
x-type owner
thank you
x-type owner
The short answer is "no, probably not" - sounds like you have the same problem as thoroughly discussed in the X type rust thread. Depending on the severity and if you do not want to have it properly fixed, it may be time to consider getting rid of it in the not so distant future.
Thankfully I have not had the issue. I took the rocker covers off when I first got the car and did a Waxoyl treatment, that might have slowed things down. Of course, I haven't opened them back up for 5 or 6 years so who knows! It's not coming through the paint yet if there is corrosion...probably some in there just not real bad yet.
It is a total bummer. The repair can be costly but can be done. I guess you'll just have to debate the merits of keeping vs. selling or trading it in. Of course, having not seen your exact problem I might be assuming the worst and maybe it's not that bad. Got any pics?
Hello,
As has been said already, this is the first sign of the dreaded inner rocker panel / A-frame corrosion. I spotted the same rust bubbles on my '03 at the end of last winter. See my thread "03 X-Type Rust" for the details. Unfortunately, by the time you see the rust emerging from below the front door hinges, it's already widespread beneath the entire rocker panel. Once you remove the plastic rocker panel cover, there's an external steel rocker panel and beneath that, is another steel inner rocker panel that is the culprit. It appears to be very poorly rust-proofed and it corrodes, eventually spreading to the outer rocker panel. The plastic cover hides most of the damage.
It is repairable but the $6500 cost approaches / may exceed the value of the car.
Good luck,
Steve
Good luck,
Steve
[quote=steve12955;247256]Hello,
maybe the part under the door hinges can be fixed replaced for 500-600 bucks by taking off the suraface rust , want is your plan with your own rusting x type steve?
Hello,
For the amount of labor required to get at the visible rust area (removal of bumper, front fenders, front doors, moldings) and not knowing how extensive it is until the plastic molding comes off, I wouldn't think that $500 is well-spent - plus it's likely that the rust will reappear in the untreated areas - so it's really a "buying time" repair.
I outlined how I repaired my car in the thread "03 X-Type Rust" elsewhere in this forum. I attacked the visible rust-through by welding-in patch panels in the A-frame area and attempted to halt the corrosion further back in the rocker panel by coating it internally with POR-15 (an extremely hard rust proofing paint) and Wax-Oyl (a paraffin-based liquid that flows when warmed and once hardened, seals the rusted area). I didn't cut away the entire rocker which is the only way to properly fix it. I spent about $175 in materials (POR-15, WaxOyl, primers, paint, molding clips, etc.) but invested about 40 hours of my labor in the repair. I hope it lasts.
Good luck,
Steve
Good luck,
Steve
Hello,
Good luck,
Steve
Good luck,
Steve
Hi guys.... I read the other thread regarding the X type rust issues, but was unable to view the pics attached. I'm a new member, and when I attempted to view pics, system advised I do not yet have authorization. I'm fairly a noob when it comes to vehicles... but in reference to the rust, are the rocker panels the area of the car that when you open the door, you see the flat silver strip with "Jaguar" embedded into it? the rust is visible when you pull that strip up?? Or is it the entire strip of paneling (same color as exterior) that runs the entire length of the car with no jogs in it? I have a 2004 X type, and could see no visible signs of rust, nor could I see the holes drilled into it that others mentioned. Knowing my stupidity, I am probbly looking in the wrong area.
99xk8guy
06-05-2023 06:28 AM
