scan code understanding help please!
had the P codes scanned for me yesterday and i understand some of them like the MAF and IAT. but i got a couple codes i have no clue what they refer to.
P1638 - CAN ECM / INST network malfunction
P1603 - TCM EEPROM failure
any help would be appreciated. thank you ahead of time
You can download the full list of DTC's in our download centre here https://www.jaguarforums.com/forum/g...r-index-50609/
The X-Type is the X400, there is a section "Jaguar Fault Codes" and the file is "400OBDII_2002MY"
The document is the official DTC list from the JTIS, which also gives a list of possible causes for each code.
i have all data and it says could be :
P1638:
CAN open circuit fault - INST to ECM
CAN short circuit fault
INST failure
ECM failure
what is CAN? what is INST? is ECM engine control module?
P1603:
battery disconnected while ignition is switched on
B+ power supply circuit: open circuit
TCM failure
is TCM transmission control module? what is B+?
P1638:
INST failure
ECM failure
P1603:
TCM failure
philwarner
25
06-26-2021 05:43 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
