Screeching rear wheel when turning left
Mornin all.
When making a left turn im hearing a pretty loud screech/squeek sound relative to wheel speed coming from the left rear wheel area.
I replaced the rotor thinking maybe it was warped and rubbing but the noise is still there.
Is there a universal joint or cv joint behind the rear hub that could be causing this?
If so, is it replaceable or would a new half shaft be required?
Mornin all.
I'll try grinding the pad "ears" a little and see what happens
So i put vice grips on the end of it and was able to get it out, it was not "sliding" for sure!
No visible damage to the rubber sleeve, but i suspect its just old.
I re-installed the pin without the rubber sleeve. Does anyone know if this will cause problems?
Im leaving on a 900 mile trip tomorrow so cannot order a sleeve in time
Received 3,886 Likes
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
SingBlueSilver
08-27-2015 02:20 PM
