Screen washer not working
Guys any ideas the screen washer and side light washer is not working I can here the pump working and the wipers move across the screen but no washer water comes out of the washer jets ho the resivoir is full .
Any ideas how I can fix Thanks forgot to say 2.2 diesel X type 2007
Could be a blocked filter, the filter is rubber and a part of the sealing grommet the pump pushes into at the bottom of the washer bottle. You access it from the wheel arch, there are 3 screws bolts holding the liner in place at the bottom, remove these and lift the liner up, pull out the pump and then the grommet/filter and clean the filter.
The filter looks like this.
![](http://www.mjtemple.webspace.virginmedia.com/WashFilter.jpg)
Paul M P (07-24-2015)
al_roethlisberger
09-11-2015 10:04 PM
philwarner
09-05-2015 10:05 AM
