Sealed Transmission Issues?
Hi, all!
I'm new here, but I don't have a Jaguar...yet. I'm seriously considering one right now. A 2007 X-Type, Jaguar Racing Green w/ Champagne interior.![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
I apologize if this is something that's been covered in detail before.
I heard that the sealed transmission could be an issue. Is this true? If so, when (miles) does it typically seem to begin?
Thanks!
Thanks!
It isn't if you buy a manual tranny
Seriously, the tranny, like any awd automatic tranny suffers from excessive heat and therefore quicker degradation of atf (consistant fluid changes once it reaches its flash point are a must). Of course the car industry thinks your too dumb (along with every other driver) to judge for themselves when your fluid has gotten too hot and needs changed to put a real tranny temp gauge in there so personally I wouldn't buy an auto tranny awd vehicle whether it was made by Honda or Yugo if it didn't have the tranny fluid changed every 20-30k regardless of how nice it looked or I was paying a price less then current market value less the cost of a new tranny.
Other issue with the tranny would be same wear of al 4 MATCHING tread patterne tires. If not shop elsewhere and then there is the tranfer fluid on the X type and fairly weak transfer case..
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Because the auto has a computer, a bunch of sensors (5) and a bunch of solenoids (9) and one of these may not work at any time. Too complex!
Lets put it this way, this is my first experience with Jaguar. A 2004 xtype awd automatic, nobody tells you to change the tranny fluid, so of course mine burned up at 42000 miles. I got it with 3000miles and dont race the car, for I am 50 not 20. I got really pissed off because of it was out of warranty on time. Of course the tranny shop told me that you do need to change the fluid every 30000 and its an inherent problem with the car and Jaguar has been aware of it for quite a while, never sending owners any kind of notification. Also now I occasionally get the DCS fault message, but luckily I did have the foresight and bought a warranty about a month before the tranny blew,(thank god) for small favors. Factory Ford warranty costs megabucks less than a Jag tranny!
Maybe you can answer my question as you sound quite knowledgeable. I heard that by having different tire patterns on the front and rear of an auto xtype, it will burn up the transfer case. Do you know if this is true as i just replaced just my front tires and have different rear tires on now. Would appreciate any help.
Oh wow. I had a 1996 Chrysler Town and Country with more transmission problems than Carter has liver pills. One reason I bought this car is that Consumer Reports rated the engine and the transmission top notch. The dealer said the transmission fluid never has to be changed because it's sealed. So.... should I get the fluid changed or leave it alone. It has about 75,000 miles on it at six years old.
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
