Security Failure + P01603
Hello Jaguarforums members,
I spotted a few threads with the P01603 code but none of the threads fully capture what I am experiencing with my 02' 2.5L X-type so I decided to start one, given what I am experiencing.
I will try to condense as much of this as possible so that this doesn't become a book.
Wanted to mention these two separate issues first, before I explain what is happening as I think they may be related.
I didn't want to drive it with the Stabilizer Bar Link broken, so I got the parts and proceeded to install them. I drove the car up on some ramps, jacked it up a little further to get jack stands under it. Took the wheels off, and proceed to change both the passenger and driver side Stabilizer Bar Links. I then tried to get the ABS sensors off but they were way too rusty so I decided to wait on that thinking that maybe the Bar Links could have had something to do with the sensor since one of them was broke.
So, I was done. I put the car back onto the ramps, jumped in and tried to start it up but the on board display said that there was both a Security Failure and Gearbox Fault. I turned the key off, tried again a couple of times and then decided to check the battery. Tested full (the battery is about a year old at this point). Hooked the battery back up and I then proceeded to manually get the car off the ramps by putting it into to Neutral and pushing it backwards. So the car is now level. Tried to start it again and I was getting only the security Failure error this time (as well as #2 from above). I decided at this point to leave the battery disconnected for a while to try and reset the computer and grabbed my OBDII reader. Hooked the battery up, proceeded to see what I could get on the OBDII. The code that I pulled was the P01603. The car still will not turn over (issue #2 from above happening intermittently). All accessories, AC, lights, locks work normally. The break petal however is very stiff.
I then proceeded to
Swapped out the R8 Relay (for the TCM). The R8 relay had a little dark spot on the side of it. It almost looked like a burn or something.
Took out the ignition Barrel and cleaned the crap out of it. A lot of gunk (and even some lint) came out of it.
Cleaned the battery terminals, positive and negative cable ends that connect to the battery as well as the two ground locations (by the headlight and on the transmission).
Cleaned the starter prongs where the cables hook to it.
Moved the shifter thru the gears to make sure that it was in Park.
Tried my second key.
I also had electrical issues a couple of years ago and ended up replacing the alternator twice but it ended up being the battery cables that were the culprit. So the battery cables are used but recently replaced.
I am thinking that it is the ignition barrel again (still seeing the issue from above) as P01603 can also mean that the ignition was on when the battery was disconnected as I've never had issues with the gearbox before and I've babied this transmission and rear differential with Royal Purple several times over the past 4 year to prevent any type of transmission failure(s).
Silver Lining: I did end up getting those ABS sensors out by the way....they were cemented with corrosion and rust. Took me about 30 minutes for each side. Horrible experience but they're out. Ordered some new ones that should be here later this week.
I disconnected the battery again and left it sitting until I try to get a clue on what to do next.
I'm very frustrated with how this all came about and hoping that someone has some insight. Any help would be greatly appreciated (as always).
Xx_Xtype_xX
- The ABS and Brake Light have been coming on intermittently for the past few months, namely when the car seems to be driven for a while. When i start it up from siting a while it, the ABS light is off. There hasn't been a code thrown for the ABS and brake light, so I thought that it is probably a sensor going and I'll just replace the front two first and then the back two later.
- I've experienced a few issues with the ignition barrel in the colder months here in the midwest and used some graphite lock grease to help the wafers/tumblers inside the lock and it seemed to have worked for over a year now. When I would turn the key in the ignition it would say Security Failure and would not turn over. I would take the key out and the alarm/chime (that goes off when the key is in the ignition remained on). I noticed that the little metal flap inside the barrel was not closed so I tapped on it with my finger and it closed and the alarm/chime went off. This has happened a total of 3 times in the past 4 years.
I then proceeded to
Xx_Xtype_xX
I ordered a new ignition barrel from Jaguar. I guess it is matched to my VIN so I wont need to get another set of keys made. Its coming from the UK so it’ll be a while before I get it. I was able to put the new ABS sensors and Relays in today as well as try to start it again.
When I hooked up the battery the locks kept on trying to unlock themselves over and over again until I hit the unlock button in the key fob.
Is there any way to tell if it is the ignition switch vs. the barrel?
Update: I put the car into TEST mode and found that the battery voltage is reading 11.8-11.9v.
As I mentioned in my prior post I hooked the battery up to a charger and it read 100% full.
Now I am thinking that the “new-used” cables may be the culprit behind this whole issue again.
If the battery tests at 100% on the charger then can someone confirm that it is the cables (as the car TEST mode is reading 11.8-11.9v)?
Thanks in advance to anyone who can help/advise.
Update:
I replaced the negative battery cable and tried to start the car and had the same results. I then replaced the ignition barrel. The new one definitely felt better when turning the key. However, the car still displayed the same issue and wouldnt start.
I then decided to open the battery caps and check the battery acid. Each cell tested on the low side of fair.
Went to Napa and bought a new battery after they tested the old one and said it tested good, but on the low side of good (i.e. its on its way out).
Took the new battery and hooked it up. The car started right up!
Third battery in less than five years...they sure dont make them like they used to.
Im going to just bite the bullet and get a higher-end battery as these Napa batteries seem to not have enough juice to carry the load these cars need.
Thank you for your help!
Update:
glad we could help
