Sensors
Sensors
Of course my engine light decides to come on a while back. Just now getting around to getting it fixed. Well the code is p0420. So that's why it hasn't been an urgent fix. But now the light is just getting annoying I've looked through JTIS and other threads and found that it is probably a bad h02 sensor. I have used Lucas injector cleaner in the past, but not in the last 5 months. Could this of been throwing off the sensors? But then again, the code is still coming up, long time after use. Basically, is it more than likely a bad sensor? And is it a fix I could probably do without working on it a week (if so is there a way to see if a sensor is bad and how to replace) or would it be easier to take to shop.
P1111 means that a full drive cycle has been completed and all emmission tests have passed since the last code clearing. That is why you need to clear the codes now. It may have been thousands of miles ago that the p1111 was set. You want to start from scratch and see if you can either get another p1111 or get your p0420 code to reset.
