serious mud gaurd problem
All right so a cople months ago, i had rust and other probelms, now im hunting doen the rust. So i purchased these mud gaurds from ebay and it said for all years for the jaguar x type, so yesterday i went to plce them on the rear and its seems the wholes for the bolts are a bit offf, wtf, its said all year. So my question is are the 2002 rear and front mud gaurd a abit different then the 2004, and what can i do about it if they are, just drill new holes in the mud guards ?? any hepl is appreciated, spent a hour and half tryin to get them on.
Are they definately the correct mudguards for an X-type (with buying from ebay wonder if someone else perhaps is struggling to fit their new mudguards to their car as well if they were mixed up unless they were sealed with the instructions relating to the X Type in the pack perhaps!)?
They should go on no problem if correct I would have thought.
that's odd then. They should fit all model years except as previously stated the wagon body styles.
So, looks like your choices are:
1) drill new holes as needed and bolt them up. Are there bolts or screws in the existing holes that you state are in the way? If so, remove them and run them through the mud flaps as well. Ain't nuthin hard about drilling through a mudflap.
2) F it and go without mudflaps and pawn them off on somebody else.
By mudguards... do you mean the plastic/rubber mud flaps that fit at back of each wheel arch?
If the holes don't match up I wouldn't go drilling any new ones in anything but the rubber mud flaps themselves. Is it possible you've got the front and rear mudlaps mixed up somehow? (just a thought)
When you do get around to fitting them, it is worth partially removing the plastic arch liners and having a clean out behind these.
Mike
Mike
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 06:46 PM
