Shifter won't go into park
Guest
Posts: n/a
I have a 2003 X-Type with the 2.5 automatic. Last night when I tried to put the car there is resistance on the shifter and it pops down to reverse. If I put the car in reverse there is no power to the wheels. Drive seems to work with problems. I had to hold the shifter in the park position while I removed the key. There was a rapid beeping for about 5 seconds before the car became silent. I have the parking brake on now. Any ideas?
The first thing that I would try is adjusting your shift cable. If you look at the trans where that cable connects(under the car) there is a shield with three 8mm bolts. Take the shield off and you'll see the cable and there will be a 8mm bolt going through the cable. Put the shifter in neutral(they make a tool to hold it there, but you can have someone hold it). Then loosen the bolt on the cable. I usually shake the cable a little with the bolt loose and the cable adjustment should move to where it needs to be. Then just tighten the bolt on the cable and you should be set.
Jklos (07-18-2024)
neruda
10-18-2015 01:19 PM
