Short Commutes - Bad for car?
I thought I once read that short trips are more wear and tear on your engine.
My commute to work is only 0.9 miles. That means the temp gauge hasn't even began to lift off the floor by the time I'm shutting her back down.
Is this bad for my vehicle? I drive very gently when the car is cold. Even on longer trips, I baby it until the engine is at operating temperature.
Weekends are different. I may drive an hour or two on a weekend night. Does this make up for it?
Thanks.
Thanks.
I must ask, why do you drive a 0.9 mile trip?
I'm not entirely sure that's really worse than driving longer trips, as you'll be doing the cold starts anyway irregardless of the length of the trip.
I've heard somewhere that each cold start stresses the engine as much as driving several hundred miles with a warm engine, or something, so minimizing them would be ideal.
Received 2,263 Likes
Short trips are indeed very hard on a car. Accumulated fuel and vapour in the crankcase never gets a chance to evaporate and can contaminate the oil. The exhaust system may corrode from the inside out due to accumulated moisture. You may wish to follow the sever service recommendations in the owners manual.
Received 9,011 Likes
Received 3,912 Likes
Keep in mind also that as the motor warms up, things expand at different rates and the motor was built around having all parts at some temperature. When the motor is cold, the tolerances of the engine are different and it can affect how things move inside the engine. Some items may end up with smaller clearances (which worst case could result in restricted oil movement, say on your connecting rod connections to your crankshaft) or with excessive clearances (valve guides in the head where you have aluminum heads and steel guides).
Please keep in mind that these tolerances were taken somewhat into account as the manufacturer knows no car is fired up and maintained running until it is sent to the junkyard. SO, there is some give here.
I don't think you are necessarily hurting the car doing the daily commutes as long as you are getting out and giving the car a good run on the weekends. This will help remove any moisture that may be building up during the week. But, at the same time, you are not doing the car any good either.
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
As an Alfa owner..we have a system to compensate for this problem..it is called an ITALIAN TUNE-UP, WHERE YOU GET THE CAR OUT ON A NICE DAY AND DRIVE IT FAST FOR A RELATIVE LONG TIME. This will get the car up to operating temperatures, and blow out the c%*p out of the engine. As our spyder is an 86, and still runs like new, (my wife thinks with the roof down, even better) we are positive that it works. Just a thought, not a scientific proof.
![Icon Rally](https://www.jaguarforums.com/forum/images/smilies/icon_rally.gif)
It boils off the accumulated condensation in the oil.
If your commute is 0.9 miles then so be it. You didn't buy it to park it. Although letting it warm up to the quarter mark couldn't hurt. Also more frequent oil changes.
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: 1991 xjs v12
DrScientist
12-09-2015 07:36 PM
thedugger1
09-24-2015 05:32 PM
