Should my boot lift itself up?
Hi all,
just picked my 2.5 AWD and I'm pretty pleased with it. One question - on my S type, if I used the remote boot release, the boot would spring open. On the X type it unlocks, but then needs lifting up. Is that normal, or is there a gas strut defiency here?
thanks
thanks
Usually open an inch or so, just to clear the lock, if yours does not move at all then there are these
Search results for: 'x type jaguar'
This was planned but did not work as hoped
Jaguar X-Type auto boot open
Very interesting, thankyou. If a little dissapointing.
It seems we think that stronger gas struts would make it too hard to close, and yet the S Type does open itself using only the struts. I can't imagine the boot is so much lighter, but some research there is called for. I'll try and get myself next to one and compare.
I would press the trunk(boot) opener and the lid would not even open enough past the secondary position. I had to lift the lid while I was pressing the remote. I discovered I had the missing "trunk poppers" on the hinges. I replaced the poppers and a drop of oil on the hinges solved the problem. The lid doesn't open all the way up, but I don't like that when it is raining.
Stuart@VelocityAP
06-29-2017 01:39 PM
hardwired
02-24-2016 09:13 AM
Brian BigSkip Skipper
01-27-2016 02:35 AM
