Side indicator repeater (wing marker) not working
I have a side indicator repeater (right-side wing marker) not working, the front and rear indicators work.
I have replaced the blub and indicator repeater (wing marker), this has not fixed the issue.
Are there any modules that control the side indicator repeaters? If so where would it be?
Or is the side indicator repeater hardwired into the front indicator?
Received 3,887 Likes
Graham, the side marker light is wired in parallel with the running light in the high beam (inside bulb of the headlights). So, if that small 5 watt bulb lights, then you know the fuse and the wiring is good. This would lead me back to what IOWNME said and that your problem most likely lies with the bulb base (the piece the bulb mounts into). Before you start getting into this too far and waste a lot of time trying to figure out things, replace that base and see what you have at that point.
If you insist on troubleshooting it, let me know. I will give you step by step on how to rule things out. I just need to know how comfortable you are with using a multimeter. If you aren't, I will give you step by step what you need to do.
hlgeorge, thanks, guess i got all my lights mixed up. Granted, the same situation is true though. The turn signal and the turn signal repeater on the side are wired in parallel with each other. So, if the headlight turn signal is working, then the problem is isolated to the wiring between the headlight plug and the repeater.
