Simple Question: Transmission Cooler Lines
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hey guys, just had a straightforward question that I haven't been able to find any information on. Looking at the cooling of the X Type automatic transmission, which is the "fluid out" line and which is the "fluid in line" on the transmission cooler?
>see attached image
>see attached image
I could have answered this a few months ago when I had the engine and transmission out. I test spun the engine with the sparkplugs out when I got the engine reattached to the transmission. Copious amounts of fluid did come out of one of the cooler lines but I don't recall which it was. I'm pretty sure it is the one on top that is "from". But I won't swear to it.
If no one can answer and it's important enough, disconnect both of the hoses and feed them into separate catch bottles. Disable the ignition or fuel supply and spin the engine for just a few seconds. The one with the most fluid in the catch bottle is the "from the trans" line.
But chances are pretty good that somebody knows without going through all this, so you might hold off on that to see if someone else replies.
aCapiz (09-08-2013)
Thanks, yeah I'm also leaning to the top hose being the "from transmission to cooler". If I can't get a concrete answer I will just do what you described.
Received 3,892 Likes
aCapiz, well, I have been searching high and low for the answer and I have found lots of great info, but not which line is what. One option is to simply take the car for a drive and then touch the lines to see which one is hotter. The hotter line will be the one leaving the tranny and going to the cooler. If you have an IR thermometer, that would work too so you can get a relative temp of the lines too.
Otherwise, I think you are going to end up doing what the one member said and to remove the line and see which end the fluid comes out of.
aCapiz (09-09-2013)
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Top is out, bottom is in. I just tapped into the line and installed this, . ID of the lines is 3/8.
Sleeperau (04-14-2024)
aholbro1
08-05-2021 05:02 AM
