Slight Leak/Knock on Bottom Engine
Hi All,
I have been advised by Jag that theres a leak/knock on my bottom engine at the sump area, hence the bottom gasket needs to be changed and the oil drained and replaced. Has anyone experienced this and how much it will cost to fix (labour & material wise). Thanks.
Thanks DPK. I am thinking along the lines of replacing the gasket and doing an oil change as the previous owner didn't do any service on it and then see how it goes. The knock as the mechanic described it is very faint, unless you mute everything around, it can't be heard. The engine still runs super smooth, doesn't loose oil and water, still wonder why the leak.
Lagonia
04-04-2016 09:23 PM
