smartphone bluetooth connectivity with Jaguar
Received 4,304 Likes
Thanks to Stuart S for great info below:
"Will my smartphone connect with the Bluetooth in my Jaguar?"[/I]
Here is THE DEFINITIVE SOURCE: Vehicles - Jaguar Click the link and you can search (1) by model and year or (2) you can enter your VIN.
![](https://c2.staticflickr.com/6/5829/22369636729_dd8f6a8f84.jpg)
If this was helpful, please press
at the bottom right.
Stuart
![](https://www.jaguarforums.com/forum/images/kirsch/buttons/post_thanks.gif)
Stuart
The following 7 users liked this post by sklimii:
938001 (07-18-2017),
David J. Lemos (09-01-2019),
Eskay (08-19-2017),
Msteiner (06-09-2016),
Nenito (08-10-2016),
and 2 others liked this post.
Posted elsewhere - Repeat
Really should make no difference. Bluetooth is upward and downward compatible. Whether it is BT from an Android, or iPhone(y) or tablet or whatever should not matter. Making a device discoverable is relatively the same on any device. The only difference could be what the acceptance code might be, and one of the devices should prompt you with a suggested code. If all else fails, try 1111
The following 3 users liked this post by Choptank:
The following 2 users liked this post by newbee:
BudL1te (03-21-2018),
Stuart Beattie (06-23-2017)
Remote x type - you may have to remove/delete the Nissan from your list of Discovered devices. While most of them are not used on my Galaxy, my list has a mouse, keyboard, 3 different headphones [that I renamed for identification], 2 laptops, a desktop and 4 separate vehicles that have been discovered. Sometimes I have to go into Bluetooth and turn it off and then turn it back on for the connection to be successful - particularly if I have been using the handsfree in the Jag before I go into the gym to workout while listening to music on my headphones.
My X-Type didn't have Bluetooth on the invoice when I bought it in 2006. A year after purchase my phone showed "Jaguar" and there began my quest to connect to it. 3131 was the code and it works great for a week or so, then it starts to get wonky: wife calls and gets what I'm listening to on the radio head-unit (and I have no idea I have a call). Half the audio fails, so I can hear but not speak, or vice. versa. Now I just ignore it. My other 2008 vintage Acura MDX has similar issues... Bluetooth in the car head unit is better today than it was before 2012... Sorry but I just gave up...
Attempt cd mod (audio in ) all rigged up on bench tried every Ave, I have the unit apart, with disc playing silent disc with ribbon cable placed cd unit out head unit. The chip you tap into only allows digital to be processed, on the other hand a tape model allows analog in, but you cannot switch to tape to allow input via cd model!! I'm using schematics for the chip and probed using live ipod for sound I tested with 3.5 Jack in iPod with pin test probes other end , convinced it won't work,, any ideas /?? (what would happen if I put cassette unit in optical loop, would speakers play via cd unit?? I don't have optical lead to try. This what I put UK forum can anybody throw some light here , my American friends ??
I think you can get the OEM bluetooth Jag module, but way to expensive to buy it used. Best bet is getting just a cheap bluetooth speaker on the visor. Will save you a ton of money. To retrofit a car over 10 years old with new tech costs more money than you want to spend on the tech. Save the money for upkeep and maintenance. Just my 2 cents. If you replace the stereo and face plate for a double din aftermarket, that might be your best bet to get a nicer stereo and bluetooth.
The following 2 users liked this post by carcster:
nedintexas (10-15-2020),
rocket11 (01-20-2022)
For touchy screen equipped. In Jag's phone screen Try ##3#*# then press green phone button. Discover me then comes up Go to your phone's bluetooth, make sure bluetooth is turned on. Make sure phone's bluetooth visibility is on. Select search. Jaguar should appear in bluetooth devices on phone. Select this. You should be asked for Jag's pairing code which in UK is 1313 (not 3131). Your phone should now be paired. You may get other requests on phone to make phonebook available
jczaban (06-20-2018)
Hi,
You guys seem to know about the phone system so hopefully can help.
My 2.2D SE has the phone option on the dash but when pressed displays 'No phone system installed'
I'm thinking eBay but not sure about all parts neededplease could you advise what parts I'd need to get it up and running?
on that year the jag had a star tac phone fitted in the center console if memory serves. When you press the phone logo it comes up no phone i would guess as the prewire for the onboard phone was an optional extra for that year i believe .
