Snapped rear wheel stud
I snapped a wheel stud on the left rear hub. Is this an easy job? Does the entire hub assembly have to be replaced. It seems there isn't any room to hammer in a new wheel stud since there is a dust shield in the way behind the hub/rotor.
Does anybody have the correct sized/threaded wheel stud I would need and correct replacement lug nut?
Evan97 (10-15-2020)
Thank you. Do you have a diagram for how the dust shield comes off? I've done rear brakes on an X-Type before but I have no idea how to remove the dust shield. Does it simply unscrew and then you can take it off the axle? Or does it slide back and remain on the axle?
Follow this link to download a free catalog for the x-type : https://www.sngbarratt.com/us/#!/English/Downloads
You first have to remove the caliper and caliper mounting bracket, then the brake rotor and dust shield will come off.
