Snow tires and better photos
I figured since I posted these on stanceworks, I'd throw them up here. Washed the car today (hence the slight headlight moisture). I may put narrower adapters in back (25mm instead of the 40mm I have on now). I kinda like the aggressive look from back though and don't think it looks too... Latin-America-fitment-influenced (you may know the look I'm referring to. Trying to be politically correct without using the first four letters of our country neighbor to the south). What do you think? Keep or bring the rears in 15mm each side? I already have the 25mm adapters in my garage, so I don't need to spend any money to have them.
40mm is currently winning at a 2:1 ratio on StanceWorks.com
http://www.stanceworks.com/forums/sh...ad.php?t=12657
I would have made a poll here, but knew all here would opt for whatever made it look more factory-ish (and to get more than 5 responses might take a month or more), so I wanted a stance community-biased opinion.
I may try one corner tonight to see what it looks like though.
Received 9,011 Likes
Lenny Stahl and crew have been doing this for decades. Adapters are easy and will have studs. Minimum width is 20mm and you need open-ended conical seat lug nuts to use them.
They can even redrill 5x112 wheels to 5x108 and as scary as most mod wussies think that sounds, my friend is the most **** tire balancer I've ever known and his redrilled TSW 20's on his S80 have been perfect and mounted for more than a year. When brand new cars go to SEMA and need to get wheels for something else to work with fast turnaround, they call Lenny.
j_bond (12-06-2010)
Hey Jeremy
The question is what are you going for? Originally I thought you were going for a sport / luxury car. But with the rear wheels bulging past the wheel well (which I did notice on the last batch of pics but thought it was a bad picture) I'm thinking more of a hydrolic jumper.
Definately go with the narrower spacers, the front wheels tuck perfectly.
flush, clean, nice... I realize you are utilizing the 40mm look as part of a car subculture many of us are not acclimated to. So I wouldn't take offense.(I'm assuming you didn't)
but nonetheless, I admire your tenacity and any project that becomes symbiotic with the driver... I LOVE car projects, however they assimilate and take form....
Do you happen to have a close-up of your rear wheels, tires and arches? I can assess what it will take in terms of fender clearancing. You may need to rent a fender roller to get 20mm under the back of your car - assuming you are keeping the 19s on there.
I'm quite sure I'll have to roll the fenders, the comfort shocks aren't stiff enough. I may consider implementing sport shocks all-around just to make it happen... The rear shots of your x-type are just fantastic! Aggressive.
Funnily enough, I have a fender roller. I've done the flush-look on several of my vehicles, so I'm ready to go. Thanks for looking out!
That's what I was thinking. I much prefer the stance and look with the 40mm spacers. But for a winter setup, for practicality reasons, the 20mm setup makes much more sense. It'll keep the rear bumper a little cleaner too. Just a little. lol
Yeah. I'm still a little poked (maybe 5mm outside the fender line), but I used to be about 20mm outside of the fender line. That is a mile in offset terms.
Hey Jeremy
