So, who has the most miles?
I'm right at 155,000, original tranny, transfer case, and engine here too...the only thing I've done is preventative maintenance such as the starter, fuel pump, spark plugs, etc. I did have to replace the coolant tank, and a vaccum line, but other than that no big issues. I do need to change the shocks...I'm assuming they are from the factory since I bought the car @ 40k and haven't changed them!
It has even survived an attack from a rather large tree several years back:
https://i.imgur.com/00pYsm0.jpg
https://i.imgur.com/x2zTSYx.jpg
All it took was a bit of rubbing compound...and the factory paint still looks great today. These cars are built to last with proper maintenance!
2002 3.0 194k miles
03 X type 2.5
160K, Original drive line. Flushed transfer @ 140K, replaced water pump @ 80K, all "O rings" booster pipe, plugs,thermostat and water pipes @ 130K. Needs bank 1 O2 sensor. Regular oil/filter with mobile - one . only use Bosch filters , 87 octane gas, Dexcool antifreeze,NO additives in oil or fuel(we have 10% ethenal)
I traded mine (03 X-type 3.0L) back in Aug of 2011, and it had 82,000 miles..Without any major issues.
Things I did to keep it running good over the years (in no particular order):
All in all nothing major...Never left me stranded other than when the battery failed and that was in my garage.
- Replaced all the Battery cables
- Replaced Battery once
- Replaced Water-pump
- Replace IMP regulator "O" rings
- Replaced Coolant Reservoir Tank
- Replaced Fuel Tank Sending unit
- Replaced Fuel Filter
- Changed Transfer case lube (twice)
- Changed Rear Diff lube
- Greased Prop shaft center support bearing
- Replaced all the brakes; with EBC Sport Rotors and Akebono Euro Pads
- Bled Brake fluid every other year with Jag Brake fluid
- Drained and flushed Coolant every other year with Jag coolant
- Drained and refilled P/S fluid every 12,000 miles
- Changed oil and filter every 6000 miles with Castrol Edge or Syntec
- BG Transmission service (drain, conditioned, refilled) every 30,000 miles
- Replaced Intake filter every 12,000 miles
- Replace Pollen/cabin filter every 12,000 miles
- Dash Defrost vents replaced (the Rattling SOBs) Siliconed them
- Driver side sun-visor replaced
- Had the 4 wheel alignment done every year
- Replaced tires once at 40,000 miles
#31
#38
The 2003 2.0D I'm looking at has 130K and is on a used car lot, I don't think there's much history with it as it was supposed to have been owned by a mechanic who did everything himself, I'm a little wary as I've done my own work on many of cars I've owned over the last 50+ years, but I always used to keep a record of everything, perhaps that's just me.
It's also nice to read that someone else has bought from a used car lot he one I'm considering but seems to have been well looked after, but another one the same I looked at today was quite rough and certainly not worth looking at further.
#39
2004 3.0. 145,000
I bought her last spring with 135,000. I love her to death. I've replaced the TC fluid twice. I installed a ball valve on mine and it's very easy to change. I also replaced the transmission fluid. I put new plugs in her the first weekend I had her. They were original. I owned a '01 S Type prior to this and I enjoy the X more. She handles like a sport car.
fay66 (01-16-2014)
#40
