Somewhat faint whoosh sound that's dependent on engine RPMs?
I've noticed this whoosh sound (sort of like the whoosh of turning fan blades) that gets faster the higher I rev my engine (I'd say at about 3500rpm it's like 4 whoosh per second, for example). I can't seem to pinpoint where it is coming from. It doesn't matter whether or not I am in park, neutral, drive, reverse, whatever. It seems to only be dependent on my engine rpms (it happens whether or not I'm moving). I don't know if it is something I should be concerned about. It is fairly faint, and so far none of my friends/family could hear what I was talking about. I think it is coming from the front half of the car, that's about all I know. From sitting in the drivers seat it almost sounds like it's near the tire. It must be something in my engine. Am I just being paranoid and its the sound of the crankshaft or something?
Received 3,906 Likes
sqenixs, did you just recently have an oil change done? If so, I would check the level of the oil. It may be that they over filled the crankcase and what you are hearing is the crank splashing through the oil. I would also say to check your overflow bottle to make sure that it is at the proper height. If you have a head gasket failure, that could also introduce more fluid into the crank case. But, if you are getting water into the oil, this will be pretty obvious as soon as you pull out the dip stick after running the engine as you will have a nice gray milkshake on the dipstick.
scottatl
09-04-2015 08:08 PM
