Spare tire item missing
It's for the key for the locking wheelnuts/lugnuts if you've got them.
If you have the nuts, but not the key, first thing to find out is which key you need. They have a single letter ID. Armed with your VIN, any Jaguar dealer ought to be able to tell you which one you want.
Jaguar will sell you only a full set of 4 nuts and a key for an eye-watering price. You might get one through Ebay, or you might just want to forcibly remove the locking nuts and replace them with standard ones.
The locking key does not have a good reputation for endurance, mainly if it's been subjected to many tyre fitters impact drivers.
I suspect you have nothing to be concerned about.
Re Astromorg's answer.
I have yet to see any comments on this forum re locking wheel nuts.
Most of the folks posting are in USA so I suspect USA spec is full set of normal lug nuts.
Hopefully you will never need to use the towing eye bolt.
I pulled the eye bolt out, gave it a bath in EvapoRust over night, and then buffed it clean, oiled it, wrapped it in plastic and put it back in its place. Then cleaned the places where it screws in, sprayed with white lithium, and fitted a rubber plug.
No idea why I did all that, but..... it is what it is. Now if I could find a way to take the sag out of the big piece that covers the spare tire well.....
I do not know what is the normal specification is in the USA.
Do you have a spare wheel fitted, either a full sized or a space saver ?
I would expect a car breakers yard would have a replacement but it would mean a personal visit as sending it would be a challenge re packing.
A really expensive option is to have a solid Jaguar boot liner.
Here in the UK, I have one. It has a tall lip all round and I find it good when I transport household/garden rubbish as any spillage is contained and easily removed.
