Speed Bumps Cause Yellow Light
Received 3,901 Likes
Mayor, lets clarify a few things before we get going. As for "the center of the dash", are you saying the instrument cluster or are you talking more over towards the radio/passenger side of the car? Only on speed bumps or does it happen when you hit a good size bump when traveling on the highway also? When this yellow light comes on, do you see a message down in the ODO area? What does it say?
My gut reaction right now is the wiring to your throttle is loose and you are getting a "Restricted Performance" message, which is only going to limit your engine RPMs to 3,000 RPMs. But, I am taking a guess at this.
Let us know the answers to the above questions and we'll go from there.
Hey Guys,
The yellow light comes on right above the digital odometer. Its within the MPH circle - not over by the radio.
It only happens over speed bumps - it does not occur when hitting bumps while driving.
Here is a picture of where the light shows up - you can just barely see where the light is - its just below and to the right of the silver cone on the MPH needle:
![](http://www.automobile.com/images/stock-photos/lifestyle_gallery/hash/d/b/7/1d9279fdd2d91845f0acc869078f5e37eb7a57bd.jpg)
Mayor, I am venturing to guess that it is like I said, the cable running to the throttlebody is damaged and needs to be looked at. If you can get the help of a second person, start up the car and then wiggle the cable as the other person watches the dash. if the light comes on, then it confirms your problem.
After that, you will want to check the wire bundles inside the engine compartment for signs of rubbing going all the way from the throttlebody to the ECU. From there, you will want to follow the line that runs from the ECU to the gas pedal. Because the yellow light is not staying on, that is telling me it is something not associated with a sensor on the engine. Therefore it is leaving very few things that it can be.
I am certainly not technically savvy about these things, but what you are describing sounds like what happens when driving in slippery snowy conditions and the DSC comes on. If it just flickers only as you go over the bumps could it possibly just be the traction control activating? It normally shouldn't do that in normal conditions, but maybe if your tires are really worn or something in your suspension would need to be replaced maybe for tha split second the system is detecting wheel spin.
It is probably your trunk not being fully closed.
I had the same issue over bumps with the yellow light coming on. If you look at your dash exactly when your rear wheels hit the bump, your text screen will say "boot open" really quick, then dissapear.
Drove me nuts for weeks, until I figured it out by accident, dropping someone off at the airport. Hit a bump, light on and then off. Dropped them off with suitcases, no more light (except the lil light bulb that lit up over my head).
Try that.
Try that.
Thang Nguyen
10-12-2015 01:25 AM
OkieTim
09-08-2015 04:48 PM
innzane
09-02-2015 10:08 AM
