speedo quit, abs light on, lights flash
Guest
Posts: n/a
Like it says, one day the speedo just quit. Any idea or common problems to help me start the repair.
Also when you turn the turn signal on all the rear lights flash. And finally the ABS light has always been on.
Any help with these would be apriciated
All these problems started at different times
Received 3,920 Likes
Joel, first, get the codes read for the computer and see what it says. I would venture to guess that you have lost 2 or more of your wheel speed sensors and now the computer is not sure what to do in shifting the car and whatnot. But, this can be confirmed with a reading of the codes. I wouldn't want you to go out and be spending all sorts of money on 4 new wheel sensors when it is something else.
As for the turn signals, that sounds like a wiring problem. If you have the tools (multimeter) and the ability, I will walk you through trying to get this all figured out.
rsa760041
23
09-25-2015 01:33 PM
