Speedwheel sensor
Hi all, I am replacing the Speedwheel sensor on my 03,xtype and i followed the sensor into the body of my car and I cannot disconnect the sensor from my car because that part went into the frame, is this normal or how can I get it out or get to it to disconnect the sensor.
Received 3,887 Likes
Noxparadise, sorry that I can not be of any assistance. I have not had to deal with this myself. If I remember right, if you remove the interior trim piece at the base of the door, you can access the plug there and then you just have to feel the plug back through that way. But, I am going off of memory with this.
To remove the rear seat you jusst pull up real hard the the forward corner. There are these big white one-way clips that hold the seat bottom down. If i remember correctly you will see the wiring under there as it comes through the floor. I remember getting fooled by one of those sensors when it was actually the reluctor on the axle shaft that was faulty. If you have the wheel off and the sensor out of the hole, just take a peek in the hole and make sure the windows of the reluctor can be seen and that the reluctor is not loose on the axle.
No problem. Sometimes its hard to know where someone has gone with a repair just by reading the one post. Hopefully the sensor takes care of it. I did replace only one over the years and it was a little tricky getting it routed properly.
I had it repaired but I actually noticed they replaced the right sensor ring but the fault code is reading c1175 which i found out is the left side? I called the garage and they said the jaguar dealer said there's only one sensor and that's on the right side? I don't think this is correct according to what I have read . So instead of replacing the left sensor ring they did the right..
