Sport mode not working?
Guest
Posts: n/a
Hi, I'm having a problem getting sport mode to engage in a 2004 x-type, with the 3.0 engine and 5 speed automatic transmission. When I press the "S" button, nothing happens. The light does not come on, and there is no change in the shift points. I also tried holding it down and got nothing.
Has anybody else had this problem or know how to fix it? How would I reset the transmission on this car? Thanks.
Yes, I've had the problem and read here it's very common. The only way I can get it to go on is to press it before I ever take it out of park the first time after starting it. That's pretty much how I get it to turn off too. I can't see any difference driving it in that mode and gas milage is still the same so I just leave it off.
I never had that problem, but...
I leave it in Sport mode all the time - and I hope that isn't a bad thing to do...
I do that because when its off the car randomly wanders between gears constantly (and I have read that complaint in some reviews). I believe Sport Mode causes the upshifts to occur at higher RPMs, which seems to reduce the random gear wandering.
Guest
Posts: n/a
I'm curious to know more about this transmission update? What years does it pertain to and how much difference does it make?
Also u guys mention that keeping sport mode engaged helps with gear-searching and rides the rpms out a bit higher? I wonder if this wquld yield in higher gas mileage due to not lugging the motor out with the ridiculously low downshifts?
I know this is a really old thread, but I've just had this same problem and I think fixed it. My sport mode button wouldn't work, no light when pressed, kickdown still worked though.
I removed the left carpet panel off the transmission tunnel/centre console and then located a large green connector for the j-gate selector, unplugged it for 5 minutes, re-plugged it and now it's been working for a few weeks now.
Just thought I'd pass this information on here instead of a new thread.
I had the same problem when I bought my car, the only way to enable S mode or disable it, was to press it before I turned on the car.
But It got solved once I replaced my battery, my battery was a little low I guess because my car cranked really low, anyhow my two cents are that when I replaced my battery its now working with no problems like it should, I can turn it on or off while driving or while being parked.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
