Squeaking/chirping from front noise when driving
Hi,
I have an X type 2004 2.5 v6, which has developed a squeaking/chirping noise which seems to be coming from the front of vehicle left side. only occurs when driving and can only be heard with the windows down and quite load in built-up areas.
any ideas
any ideas
Dandy: If you have wheel ramps, try this...… drive the front wheels onto the ramps, lie on your back under the front of the car, and with gloved hands (14 years of road grime down there), push up and pull down on the front subframe and suspension to rock the car up and down. You don't have to be Arnold Schwarzenegger, just rock the front suspension a 1/4 inch or so to make it squeak. Keep grabbing different parts of the suspension as you rock it up and down, and eventually, hopefully you'll grab a suspension member that vibrates in your hand with every squeak.
jagosaurus
07-19-2013 12:58 AM
adam12hicks
01-24-2009 01:49 PM
