squeaky steering
Guest
Posts: n/a
I think that got locked too quickly.. I would like to discuss a little.
What sort of squeak was there to begin with? my car has a slight noise that sounds more like the horn contact... imaging the sound of humming a squeak with your mouth closed softly.. that is what I hear.
was your sound like a good old fashioned loose power steering belt squeak? or something more subtle?
haha.. noises are very hard to type hehe
Received 9,006 Likes
![Name: cars.jpg
Size: 7.4 KB](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/195742d1501337617-squeaky-steering-cars.jpg)
ORIGINAL: bojangles
the reason it was FAQ'd and locked so quickly was as has been said before, for everyones benefit. It keeps the post short, straightforward and simple, which is what a FAQ should be. There's nothing worse than looking at the FAQ section for sumthing and having to trawl thru post after post to find it.
As you have that problem on your car and you want to discuss it, as I'm sure others do I have included the link below to the topic Buck posted that I made FAQ.
https://www.jaguarforums.com/m_27170/tm.htm
Jim
the replacing of the main seal was just a temp... fix, same seal we took out was the same one we put in no different.. but made lots of money doing it.. but this additive works great can't believe the 2-3 oz makes the noise go away.. i like the symbol on the bottle a dead fish lol
Guest
Posts: n/a
The noise is a squeel type of noise and not very loud.I noticed it on mine around 2 years ago.It was only noticeable at slow speeds when turning the steering wheel left or right.It sounds like its coming from the top of the steering column just behind the steering wheel (at first I thought it was the steering wheel catching the shroud on the steering column) and was annoying but I lived with it as when it was first diagnosed asI found out that it could be leftwithout causing dangerand I wasnt prepared to spend £400 getting it fixed.
When a possible fix came along for£31.78(or £3.50 DIY) then I thought it was worth trying and now I am glad I had it done..
Hmmm ;(
i do this today:
3000rpm in idle, then rotated to stop the steering wheel to left and right, every 3 times.
In this Moment came a very loud noise from the motorarea when i moved the steering wheel and the power steering reservoir is empty (today morning full).
What i do? ;( What happens?
i do this today:
