squeal from steering wheel?!
Ok so I also have a squeal in my steering wheel when I turn in either direction. It almost sounds like a cable being pulled. I think it has something to do with the power steering. Just wondering if any other jags out there have experienced this and if so what was the culprit?
Its usually the bushes that have dried out in the steering column
The FAQ at the top of the page have answers to a lot of questions including yours https://www.jaguarforums.com/forum/s...ead.php?t=2880
Received 9,011 Likes
Jaguar issued a Service Bulliten on this awhile back. The fix done at the dealership was to use an additive in the power steering fluid. It required a drain of the system and addition of new fluid plus the additive.
I had mine done under warranty or it would have not been touched by unfamiliar hands ( meaning mine ). I am uncertain if this would be covered at no charge if not under warranty.
Mark D
Mark D
Strange how your dealer drained all the fluid?
The OFFICIAL TSB as issued by Jag clearly shows that only 50ml of fluid must be removed then replenished with the 50ml of additive added (ie no complete draining required).
Only reason to drain fluid as far as I can see is if there is another issue with it ie contaminated.
FS[SouthWest]: Momo Wooden Steering Wheel
RobertTheBloke
09-24-2015 11:48 AM
1964Daimler
09-09-2015 11:28 AM
