Standard headlamp (H1 bulb) problem - Help!
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
I just replaced the passenger side bulb for the 4th or 5th time now. I'm not exaggerating - I keep a spare in my glovebox. The first time, the connector was melted to the bulb, so I put individual terminals in the wiring - hot to the bulb and ground to the tab the bulb retainer wire clips to - found that fix here in the forum. I can find no chafed wires in the harness inside the housing or leading to the assembly. What am I missing here? I'm getting tired of replacing bulbs! (Though I am getting pretty quick about it.)
First, make sure you only use Jaguar bulbs. Don't ask me what makes them different but aftermarket bulbs just don't last in a Jag. I got tired of replacing mine and went back to my stock bulbs, haven't touched them again since. Next, don't touch any part of the glass with your bare fingers, the oil destroys them.
I know some people have trouble with their harnesses but if you've done that fix already, just try a stock bulb and see if it lasts longer. Mine did, hands down.
Received 9,010 Likes
Thanks for the replies, guys. I only use 55w bulbs, Sylvania or Wagner brand (both OE suppliers), and clean the glass bulb before installing. I wonder if it's related to the ground relying on contact from the bulb to the housing. I'm going to try something odd with the next one - and there WILL be a next one! I'll solder a tab directly to the bulb's base to connect the ground to. Maybe that will help.
Wolfy
05-28-2024 08:06 AM
rentzoo
11-10-2015 04:56 PM
Ophitoxaemia
09-14-2015 02:40 PM
