Starter solenoid Clicks no start
Have a 2003 X type owned since new with no real problems till now. Starter only clicks when ignition is turned on. Has a nearly new battery, cables check out. Swapped out the starter relay and changed the starter still same problem. I am a pretty good mechanic and well equipped to work on anything pre smog and computers, my hobby is restoring vintage Ford trucks, wife's car.
Came on suddenly drove the car on day and wouldn't start the next. Any thoughts.
Thanks Robert
Thanks Robert
Thanks Robert
Thanks Robert
My car would have the interior lights on, the radio would work, but it wouldn't even try to turn over, just the clicks.
Trickle charge the car overnight and if it starts in the AM, you have a battery/alternator problem.
Good luck!
Bruce in North Dakota (11-05-2014)
Received 3,887 Likes
robert, try this: Connect a multimeter across the battery posts. With the engine off, it should read 12.6 VDC. As you attempt to start the car, watch the multimeter (may require a second person). Did the battery drop to 11.5 VDC or so? If yes, then you have a bad starter (yes, may be new, but possible). If it drops to below 11.0, then you have a bad battery. If it stays up near 12.6 VDC (12.4 or higher), then you are not getting power to the starter motor. This should help eliminate a lot of stuff and leave you with a very limited number of options as to what the problem can be.
On a side note, when you are attempting to start the car, does the red light on the center console flash at you?
Mine did something similar once and it was actually the started relay if I recall under the hood ( located in area just above the battery ). I had been messing around with something else in there and I had inadvertently moved it a little and seemed to have not made a good contact. Later pulled it out again and reseated - car started right up.
You might try swapping another relay from another accessory if possible and give it a shot if you have a minute while checking some other things. G/L
trosty
26
12-18-2022 06:40 PM
