Steering rack replacment
Hey guys, have a bad seal and leaking thru boot. I know the typical start is to remove the tie rod ends / bolts to rack and disconnect the steering column. I am not seeing the hoses to how to disconnect them ? I found a video from you tube in Russia but can not tell what they are doing, looks like they are separating the frame to make room to remove it ? Thanks for any help
Bil,
if you find while removing the subframe thet the captive nut spins (large one infront of two smaller ones)
check this post.
https://www.jaguarforums.com/forum/x...e-free-113243/
check this post.
