Steering wheel whining
Old 03-20-2006, 08:17 PM
Humy's Avatar
Default Steering wheel whining
Anyone's X-Type have the issue of the steering wheel whinning when turning it? It is a very slight sqeeking/whinning sound, but it is there. Just wanted to know if anyone had any ideas, of what it could be.
Thanks guys[sm=icon_cheers.gif]
Old 03-20-2006, 10:21 PM
racerx82's Avatar
Default RE: Steering wheel whinning
spray some WD-40 around it...should help. It's normal on a car with some miles....
________
Honda cbr900rr specifications
Old 03-21-2006, 03:14 PM
Humy's Avatar
I have no warranty accept the Select Edition Certified used Jag one... I have a feeling that means nothing... any idea on what the *********** would charge for that?
Old 03-23-2006, 01:48 PM
Humy's Avatar
thanks for the info fabulous[sm=icon_cheers.gif]
Old 03-28-2006, 03:25 PM
Patrick's Avatar
Administrator
in some cases, it may even be just a bad bushing...
Old 04-30-2006, 10:36 AM
racerx82's Avatar
If it's not the bushing, I have a brand new steering assyembly in the box from jag that i acquired. I'll sell cheap, 60 bucks, plus shipping... your savings of 2,100 dollars
________
EXPERT INSURANCE
Old 05-01-2006, 01:20 PM
Humy's Avatar
I let you know racerX if I need the assembly - the Jag is going in next week
Old 05-01-2006, 08:13 PM
racerx82's Avatar
no prob, i'll probably list it on ebay by then.... :-)
________
MEXICOCITY HOTEL
Old 06-19-2006, 07:57 PM
Humy's Avatar
Thanks for the info Tom[sm=icon_cheers.gif]
Old 06-23-2006, 09:19 PM
racerx82's Avatar
So what was it....or was this part of your 800 dollar 60K tune up?
________
Zoloft problems
Old 04-22-2013, 04:48 AM
iownme's Avatar
There is a tsb for this issue...remedy is in the jag FAQ
Old 04-22-2013, 06:03 AM
faltwen's Avatar
When I got mine it had the same whining sound. There's a fluid additive that jaguar supply for about £10. I added it to mine and it cured the noise.
Have a look here:-
Jaguar Power Steering Additive For PAS Rack X Type XJ | eBay
Although they don't appear to mail overseas but it must be available in the states.
Old 04-22-2013, 06:41 AM
Imranakhan's Avatar
Hi I have the same sound on my 2002 x-type.
@faltwen - If I have understood correctly, I buy this and add with the steering fluid correct?
Old 04-22-2013, 09:13 AM
Aonsaithya's Avatar
Yes. I did the same when my steering wheel was whining, I just added it to the steering fluid and drove around a few circles on full lock, left and right. Not only did the whiny noise disappear, but the steering became slightly smoother and lighter.
Old 04-22-2013, 10:42 AM
faltwen's Avatar
Yep, what he said.
Old 04-22-2013, 02:19 PM
emaraszek's Avatar
Perhaps this is a stupid question, but do you need to re-add this additive if you replace the power steering fluid?
Old 04-22-2013, 08:00 PM
Smith000's Avatar
Default steering whine, additive
Try here for the additive; https://www.jaguarparts.com/partscat.html
My power steering has no whine but the steering column has a slite noise in it as two of my chevy malibus have had, it comes and goes, fluid in them is not low and the steering in the 2005 is not the wheel to steering gear type it has servos that control the left and right turning of the wheels I have found that the upper bearing under the steering wheel makes a whining noise at times and can not be heard out side the vehicle with the bonnet open when the steering is turned full left and right.
2004 X-Type auto 3.0
Attached Thumbnails Steering wheel whining-p1000847.jpg   Steering wheel whining-p1000845.jpg   Steering wheel whining-under-bonnet.jpg
Quick Reply: Steering wheel whining
