Steering wheel whining
Mine makes the same noise. It isn't bad, and you can barely hear it, only when at really low speeds like when turing into my driveway.
I tried the link that Smith000 posted, but didn't see the fluid additive on there. And the only ebay seller that has it doesn't ship to the US.
Anyone know of a US source for this additive?
I seem to be having the same issues on my 2002 X-Type. It looks like jagbits.com might have what we need.
Jaguar POWER STEERING FLUID ADDITIVE - C2S48887
Also Terry's:
http://www.terrysjag.com/product/C2S48887.html
Also Terry's:
Just to confirm we are talking about the same problem. My squeak is just behind the steering wheel, you can't hear it in the footwell or under the bonnet. It sounds like "dry" rubber rubbing together or when you rub your finger on squeeky clean dry glass. It seems to come and go or be slightly louder on different days. Does the power steering fluid reach as far up as the steering wheel, because if not I'm not sure if the additive mentioned on this thread would cure it in my particular case? It's also been suggested spraying with oil/WD40 etc but having looked the steering column is pretty effectively sealed by the cover,. and I'm not sure if I am confident enough to remove it.
FS[SouthWest]: Momo Wooden Steering Wheel
RobertTheBloke
09-24-2015 11:48 AM
