Stop Leak advice???
Received 2,191 Likes
Received 3,892 Likes
You sure about that chris? Book says 2.7 and i assure you that it takes every bit. Pull lower bumper splash panel and bumper cover. Evac ac. Remove lower radiator core support(it comes out the bottom) undo wiring for fans and take them out first. Undo all lines to ac condensor, power steering cooler can hang and rad hoses. Drop out the bottom. If you dont have it on a lift you better have it up pretty high. While you can do it and leave the ac condensor in place. Its increases the difficulty immensly and you risk damaging both the condensor and the radiator.
aholbro1
08-05-2021 05:02 AM
OkieTim
09-08-2015 04:48 PM
