Strange vibration on 70mph - not a wheel balance problem
Please help!
First, exuse my English because I am from Serbia.
I am proud owner of Jag X Type 2003, 2.0 Diesel. I love my car which I bought a few weeks ago. It is my first Jag and I believe I will not change the car manufacturer in future![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
I have noticed strange vibration driving in range 90kph to 11kmph. OK, I did wheel balance on all four tyres, switched front and back, but problem remains the same. Tyres are new. Strange thing is that vibration of the complete car is getting worse as I am pushing gas pedal more and it is less when I am not pushing the pedal. Steering wheel is slightly vibrating, nothing special, I beleive it is vibration transferred from the car body shake. Servicemen said that there is no mechanical issues...
I read that soneone had similar problem and that he solved it with repairing lambda setup, but seems it is not an issue with my car![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I have also noticed that car is not going smoothly, maybe I need to recheck my filters or something...
Please help, if I solve this problem, I will be happy as a clam![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thanks in advance.
Thanks in advance.
Received 3,886 Likes
Ivan, I have a steering wheel shake occasionally in my car and it is enough to cause the seats to wiggle some. Get the front end of your car aligned. Even if the toe on the car is slightly out (as little as 0.2 degrees is all it takes), it will cause the front end to fight itself and as you drive faster, it will cause the tires to fight more and more, leading to the shaking that you are seeing.
The other thing that I would tell you to try is to get a grease gun with a needle attachment. Get under the car and repack the carrier bearing on the rear drive shaft (located under the car about where the driver's seat is located). Fill it full of grease and then see how the car drives. If the wiggle goes away, you need a new bearing for the rear drive shaft. But then, thinking about it, is your car AWD or is it only FWD. I do not recall if the diesel variants come in AWD or not. If it is only FWD, then disregard the bit about the carrier bearing. You don't have it.
ivanrodic (07-22-2012)
Did the vibrations change when you swapped the wheels front to rear? Usually, you can feel front end issues in the steering wheels and rear end issues in the seat. One thing to check is to make sure you don't have a slightly bent wheel. It can been near impossible to spot without it mounted and spinning on a machine.
ivanrodic (07-23-2012)
I have the same problem. I'v had the car only 3 week and it' too low to get under and check, but I think it's the drive shaft u joit. the vibration is coming from the center of the car or all over not the stering wheel. starts at 68 goes away at 75,80
it is related to the load on the drive train. a loose joint will go in and out of balance
What do you guys think?
To add - I had a vibration/shaking at 45 - 55 MPH - causes - worn lower ball joints, which improved the vibrations and handling but the ultimate culprit was coil #4 - intermitient misfire during engine load - and BTW - I never had a check engine light for the misfire... the forum is designed to share experiences, not discount the opinions or feedback of others.
Worn stationary parts can cause vibrations through connected rotating parts (engine - one big rotating part:internal and external , connected to motor mounts, connected to the frame/suspension/steering system)
PS - Proper spelling goes a long way...
The following 2 users liked this post by abonano:
Lcgi (10-21-2013),
pompeyphil (07-21-2023)
Sorry, I did not mean to offend. I think I was only thinking about my car. No ploblem in the fount end, I checked it, and I think I would have felt it in the steering. Yes in cars that have hight positive caster loose joints will make the car shake. There is no relationship between engine RPM and noise or vibration just road speed so there is no missfire. Maybe other people may have these ploblems so I should not have ruled them out. If you can not forgive my spelling I will never be accepted. I can't spell but I do know alot about cars. Mybe not this one
Hey fellas, does anyone have advice or a run down on replacing the upper motor mount and the roll restrictor? At high speed these 2 being worn out, could give way to some vibration. It may not be the first thing to look at when you have vibrations on the hwy, but, I bought these 2 mounts and I want to replace them tomorrow, Monday.
So, I have 2 main questions.
1) Do I need to support the engine, or trans weight for R&R of either of these mounts?
2) If so, where on the engine or trans would I safely apply the lift force?
Any advice is appreciated! Here is a pic of my top motor mount, the rubber looks broken.
![](https://www.jaguarforums.com/forum/attachments/x-type-x400-14/59306-strange-vibration-70mph-not-wheel-balance-problem-img_20130915_172356_zps6d046ae1.jpg?dateline=1382325444)
Thanks!
Thanks!
