Strange Whirling Sound
I recently noticed a strange whirling noise at about 30mph with a slight vibration that seams to disapate as speed increases. Its not high pitch as others have claimed prior to replacing their driveshafts.
Had it up on a lift running and it sounds like its coming from the tranny.
Has anyone had a similar problem? Any ideas what to look for?
It's abbout $1000 to replace. It isn't anything serious and there are write ups on here explaining how to lube the propshaft bearing. It's really the bearing that makes the noise, but you have to replace the whole thing. It's more annoying than something serious. Surf around on here, there is a TON written up about it. When the dealer did mine it took about an hour total.
Bingo...You guys were right. About 2 weeks ago it was recomended by my mechanic to replace my original propshaft cause the center bearing boot was shot and the mount was bent a bit. So I called my used Jag part guy and he had one so I had them swapped as his seemed in better shape then mine. Thats when I started to notice the noise.
I requested my mechanic to swap it back with the old one just to see if that was it, and it was!!!
I'm going to keep my old one in there for now until I hear a noise again. My Jag parts guy is a good guy and he'll take it back or give my a credit as I sure I'll be needing additional parts.
